TwinTurbo.NET: Nissan 300ZX forum - Also, unplugging each speaker will do nothing
Subject Also, unplugging each speaker will do nothing
Posted by fuzzymonkey on June 10, 2013 at 5:26 PM
  This message has been viewed 243 times.
In Reply To Bad Alternator Whine in Sound System posted by WE350Z on June 10, 2013 at 04:03 PM
Message It has to do with what sound the amplifier is amplifying. All speakers should have the wine. If you're in doubt, you could try cause it only takes 5 seconds to undo each speaker from the amp.
Just some food for thought, did you properly ground the amp wire as well? Strip away paint with a dremel so you have the best connection to the ground of the chassis? Having a good ground goes a LONG way.
The distance between your power wires and the RCA's I believe should be ample, but if after confirming the grounds are all good, my next step would be the RCA location.
